Dasselbe für mich. Ich dachte, es könnte daran liegen, dass ich mehr als ein Auto auf diesem Konto habe.
Ich nehme an, die Integration muss verbessert werden. Ich wünschte, ich hätte Zeit zu helfen
Alles anzeigen
Hi yes. It works on our alpha version.
Both Clement and I have it on our iPhones but never used it yet in real life. We prefer CarPlay
We didn’t release it yet as beta on TestFlight because we must translate in all languages. It’s only English for now.
I am not a big fan of the gps in the car. I will make an effort to prepare the translation for you to contribute in Crowdin this week. Sorry I wasn’t much motivated by it.
Do you think we will be able to set/modify the charging amps in the future?
Hello # can only copy what was made available by smart. And we find it thanks to Hello Smart.
Today we can only copy what Hello Smart does. We hope one day they will open a developer portal and we could start implementing features faster than the official app.
Volvo developer portal was created, Mercedes too. We can have hope Geely and Mercedes will give us a developer portal for smart
Hello clementgzl, good evening chriscat, could you perhaps modify the function for sending charging stations to allow sending any address? Possibly via the sharing menu?
BR
Birger
Hi!
Yes we wait for the button to appear. We’ll see if it’s just GPS coordinates that we can use for any destination. For the moment the button are missing in hello smart so I can’t see what it’s doing
Alles anzeigenHallo irger,
Vielen Dsnl. habe es auch so gemacht aber festgestellt, dass es nicht immer gut funktioniert. Offensichtlich versteht er „Smart“ nicht so gut. Werde es nochmals testen.
Gruß
Max
We can’t say it works super well with Siri
The most important part of shortcuts are for setting up the action buttons on iPhones and Apple Watch Ultra. I start preconditioning by one click on my watch.
Also scheduling something with the app shortcut: “tomorrow at 7am start preconditioning” is now possible.
Or create icons on your iPhone for the actions you need with quick access.
You can improve Siri understanding by creating your own shortcuts with your own names and the associated action
But I am not happy with it. I keep having to unplug / replug to make it detectable
Before that I had another one but it works only on car scanner and not ABRP: KW901 BT5.0 Black
Wann wird es eigentlich möglich sein, die livedaten der #Hello App an ABRP zu synchronisieren, ohne dass die App im Vordergrund laufen muss? Gibt es da schon eine Roadmap. Pump hat es ja implementiert, wäre natürlich toll wenn da ABRP auch nachziehen würde, direkt mit dem Smart Account zu verknüpfen. Bis dahin nutzen ich halt den Workaround der Hello # App.
Hi
I was contacted by pump to share information about the API we use in Hello #. It’s really different from ABRP
Pump makes the call for you directly to Smart. They need your password.
ABRP is more conventional: they provide a token and you are in charge to send data to ABRP.
I use ODB2 and hello # and I was nicely surprised to see all the benefits of hello #. For example ABRP knew where my car was parked in Edinburgh while I was planning my next day from a totally different place of the city.
We will add the support of background updates sent to ABRP. But we are ourselves on a road trip without laptop for 2 weeks. Enjoying our smart #1 on the Scottish roads we’ll work on that again in July
Hallo,
Geht die App aktuell bei euch? Ich kann mich nicht anmelden, „konnte den Kontext nicht abrufen“ sagt die App
Danke und Grüße
We were supposed to change that error message sorry. It means your internet is not working. You can’t reach the server.
So far; each time someone had this issue it was due to a VPN on their phone. Hello smart also is blocked by the VPN
On another note. Hello # is experiencing some error message issues about logging.
Pretending the token expired, which it not true. We are trying to release a fix ASAP. Meanwhile, if you ignore the Token Expired error message it keeps working. you don't need to login again
It seems the losing process has evolved with hello smart. they might have been working on improving the experience
I have this one: https://www.lxudcustomz.co.uk/…gnostic+Tool&_ss=e&_v=1.0
"ELM327 Bluetooth 5.0 OBD2 Scanner Diagnostic Tool"
I thought bluethooth 5 would ensure it would be the latest. But I read too late this brand KONNWEI was removed from the recommended brands by car scanner app.
